yogi1
.060 Over
I don't have any pics, but it's pretty simple.
1) take all the Corbin mounting crap off,
2) get a short piece of wooden dowel rod about the length of the pin on the stock seat.
3) go get your wifes lipstick, (I'm not kidding) Preferably one she doesn't use much anymore.
4) Goober up the end of the dowel with the lipstick
insert the dowel in the clip on the bike that holds the seat pin!
5) slide the nose of the seat under the tank bracket and then slowly set the back end of the seat down where it belongs.
6) lift the seat up and you'll see a lovely rose or blush spot where you need to place the pin from the original seat.
7) now drill the two rivets holding on the stock pin.
8) get a couple small carriage bolts, to mount the pin on to the Corbin seat.
9) place the pin so that it lines up with your lovely mark from the lipstick, drill two holes into the base where the rivets were to mount your carriage bolts.
10) I pushed away some of the foam in the area where the pin goes, and put the carriage bolts down through the base.
11) Attach the pin tighten with a little loctite (Red) voila.
