Theses will fit under bear claw AND YOU DON'T HAVE TO
MOVE OVER FLOW TANK , I am using them now
Any of these part numbers will fit
UP 4245ST ID 2.5 OD 4'' LENGTH 4"
UP4245AST ID 2.5 OD 4'" LENGTH 4" < ANGLE
UP4245 ID 2.5 OD 3.5 LENGTH 4 "
UP4245 S ID 2.5 OD 3.5 LENGTH 4 "
They have spring inside & they are foam , so they bend
ANGLED OR STRAIGHT
You have to oil them very lightly
3 in 1 oil works fine
You will have to press down while you tighten clamp
OR they pop off since throttle bodies don't have much of a lip
on them
Once tightened firm ( not overly tighten )
They are very smug !
New one's ON and working fine
The above I purchased yesterday , they have rubber base cup ( have spring also )
and they use a clamp , actually like them better
Picture below , was older model
That you had to use a plastic tie wrap
to hold them on
Link Removed
Link Removed
Wayne
