Owl, The only issue I see with your advise is the dealer seems to think an idle of 1200 rpm is "perfect"(their words). Also, the guy who tests drives the bike thinks it runs"better than stock"(again his words in writing on the receipt) Lastly they say r3's will tend to have a rough feel because of the huge pistons etc. Bottom line is, if they install the tps, it will be on my dime. And it may still be the idle stepper, crank angle sensor etc.
True. Perhaps you should show the dealer the handbook/manual where it states that the tickover shoud be 800?
Also true that the R3 has a different feel, same way as a twin cylinder bike will feel different to a 4 cylinder. I think they're idiots. Anyone who takes days to test a tps is a definite idiot. Maybe you should contact a different dealer, or if there are none near, contact Triumph America?
Mine was running at a high idle, and also stalling. It started when I was about 20 miles from the house. I stopped by my friend's performance V-twin shop where he told me about stepper motors and TPS'.
He adjusted my stepper motor just a bit in order to get me to the dealership where they replaced the TPS. It might be that the stepper motor needs a bit of tweeking.
Native One, Unless I travel out of state, they are all I have. Hopefully the tps will be the issue. Then I can bring the bike for dyno-tuning if necessary.P.S. That is if restoring the ecu flash to stock and replugging in the pc3 doesnt do the trick.
Even if you have to buy the TPS, (if your bike is out of warranty), that is the way to go. However, with all the faulty TPS issues, I don't think you should have to buy one, but with that said, since you have the PC III undone, they should be able to determine the TPS is bad. Then buy the TPS if you have to and hopefully you are good to go. I hope it works out soon for you. Just make sure you get the new TPS as posted earlier in this thread. Good luck! Also, there are plenty of good PC III tunes available from us guys who have PC III's if you need them depending upon your current setup!
..don't know about Icapell's, but my TPS took a dump..called the dealer, ordered a new one..put it on, adjusted with tuneboy, and all is well..many thanks to all that contribute to this forum..hat's off..
