Not to rain on the parade, BUT, first of all the Harbor Freight motorcycle attachment will not work on most motorcycle wheels. (I have the whole shebang). The center post is too large to fit through the axle bearings, so you can't use it with the included bar to take the tire off, or on. It will work as a vise to hold the wheel, but I have to use straps to hold it tight or it slips and turns. There is someone that sells delrin blocks that fit in the three jaws that would be better, but I have not bought them, yet. The included bead breaker will work, helps if you use a lot of soapy water around the beads and do a little at a time, turning the wheel as you go. A pain, but it works. Second of all, like many have said, it's easier to cut the bead. You can get one side off, but the second side is near impossible without cutting the bead. Third, mounting the new tire is the same as removing the old one. You might get the first side on, but believe me, the second side will bust your fanny BIG TIME! I tried the rim protectors. Got the second side almost all the way on, and one of the bead protectors came loose and fell inside the tire. After having fought it for an hour, and it almost on, I didn't want to start over, so tried to get my arm in there, to retrieve the bead protector. Tore up my arm on the edge of the tire, but finally got it out, and managed to pop the second bead on. Absolutely no way in hadees I'll ever try in again, at least on the rear. I now take them to my friends tire store, with professional equipment, and it takes them a bit of sweat to mount them. There's not enough drop in the center of the rim, to allow easy mounting. My first rear was done at the motorcycle dealership where I bought my bike new, and they had quite a time too.
