I had, two complaints about my 05 R3. One the headlights, two cold weather starting.
On e-bay I bought a set of LED dual headlights for $75. shipping free and, a 1.4kw starter to fit 98-05 camry.
No more cold weather start problems and I can see at night without my Wife leading the way on the V-rod!
Happy Rocket pilot.
Leading the way on the vrod, how dare you even suggest a vrod can be in front of a rocket say 100,000 hail marys or whatever it is that the Catholics do and report back
Yes very easy direct bolt on. Disconnect battery ground cable just below starter, disconnect starter motor to solenoid cable remove two thru bolts and motor slides out. Reverse for reinstall of new motor.
That must be a heavily modified V-Rod! I followed a modded V-Rod onto a dyno a few years ago and he made an absolute ton of noise and 108 rwhp. He was expecting 120hp. I made 150 with a header and K&N's.
I am only putting out 209hp at the rear wheel so the vrodcan read my plate(depends on how good a rider your wife is quite possible she will leave me standing)
