OK good info Hanso thank you.
OK so I have my Dobeck Performance AFR Plus set up with each fuel zone slightly different. The 3 zones are what I call Light Cruise, Normal Cruise and WOT. Light Cruise is set at 13.2 for idle and putting about a parking lot or something like that. Normal Cruise is set at 14.2 for general power cruising and WOT is set at 12.5 for WOT fun. I have been trying different target settings for each zone, but so far I like these numbers. The gauge gives an instant read out of where the AFR is at any given moment. (Although I would guess there is at least some lag even if it is only in milliseconds.) I see the zone number vary a little as I increase or decrease throttle. I was glad to see my MPG return when trying to ride normally (for me). One of the things I really like is getting all that heavy heat off my right leg. Also, I like that I can change each zone to my liking. Particularly the Normal Cruise. I can manually richen or lean it out with the control buttons on the gauge face for what ever conditions come up.
