Where does everyone shop for their rocket roadster parts?
syntax007
Standard Bore
2014 Triumph Rocket 3 Roadster
I see amazing bikes in the gallery, but I don't know or can't find where some of y'all get your parts from. Like the triumph branded floor boards or hard saddle bags, chrome plate for radiator. Is there like a secret Triumph shop that I'm unaware of?
Classified ads on this forum is where I have found most of my parts. EBay is good, just have to be patient, and Amazon for cheap, universal, parts.
You can always check out Ishrub’s tin shed but only for light parts, shipping from Australia can add up quick but he has a lot of hard to find parts
So you want Chrome radiator shrouds (top, bottom and 2 sides), or a front chrome/stainless front cover for radiator?
#PartStockRRPQty
Used
Basket
1Kit, Radiator Cover, LH
T2108513
THIS PART IS CHROMED
Share this part
AVAILABLETO BACKORDER$59.60excl. VAT(£46.86)-QuantityMinusPlus
1Radiator Cover, LH
T2108413
Share this part
AVAILABLETO BACKORDER$54.08excl. VAT(£42.52)-QuantityMinusPlus
2Radiator Cover, RH
T2108414
Share this part
2Kit, Radiator Cover, RH
T2108514
Share this part
4Radiator Cover, Lower
T2108418
Share this part
AVAILABLETO BACKORDER$52.43excl. VAT(£41.22)-QuantityMinusPlus
T2108518
Share this part
AVAILABLETO BACKORDER$57.40excl. VAT(£45.13)-QuantityMinusPlus
9Rad Cover, Upper
T2108417
Share this part
They also came in about 23 different painted version to match all the R3 paint schemes over the years.
The other option some of us have are the small batch custom made neater and smaller stainless radiator shrouds from a UK member @hogweed which came either polished or powder coated black.
Triumph branded floor boards - I have been selling those Chromeline rubber mat inserts for a while. Still have some new sets with matching h'way pegs and brake pads.
If you mean the floor boards themselves there are 3 factory options you can fit to your late model Roadster.
Some folks with used bikes do not like the floor boards and swap them for either of the factory the foot peg setups and vice versa.
There was an accessory Footboard set A9758085 available until about 2012 from Triumph which gave increased angle clearance when cornering than both footpeg and the Classic floor board A9758081 setups and they (A9758085) are now impossible to find new (I sold a couple of NOS A9758085 sets last year). The Classic version was available as an accessory but most were sold installed on the Classic model two tone R3s.
You can also cross fit the R3Touring footboards and footrails to the Roadster and an Aussie member did that a year or two ago at a cost of about $1800 in parts alone from Triumph and many of these are now hard to get too. All 3 sets have slight difference that do not allow reuse of the Roadster brake and gear levers as they are.
Any Triumph factory foot-board option requires the matching but different footrails that can all be bolted up to any Rocket.
If you search these part numbers A9758081/ A9758085 on the forums you should find threads detailing them all and you can see what is/was available and put a wanted request in the Classifieds and wait.
Hard saddle bags,
CLASSIC FOOTBOARD KIT A9758081 Includes Rocker Gear Lever
#PartStockRRPQty
Used
Basket
1Foot Control Mtg Assy, LH
T2083008
Share this part
AVAILABLETO BACKORDER$162.26excl. VAT(£127.57)-QuantityMinusPlus
2Foot Control Mtg Assy, RH
T2083010
Share this part
1-3IN STOCK$162.26excl. VAT(£127.57)-QuantityMinusPlus
3Bolt, HHF, Lghtd, M8 x20, Enc
T3205254
Share this part
IN STOCK$0.94excl. VAT(£0.74)2QuantityMinusPlus
4Footboard, Die Cast, LH
T2083000
Share this part
AVAILABLETO BACKORDER$96.03excl. VAT(£75.50)-QuantityMinusPlus
5Footboard, Die Cast, RH
T2083001
Share this part
1-3IN STOCK$96.03excl. VAT(£75.50)-QuantityMinusPlus
6Rubber, Footboard
T2083006
Share this part
1-3IN STOCK$44.15excl. VAT(£34.71)-QuantityMinusPlus
7Pivot Pin
T2083017
Share this part
AVAILABLETO BACKORDER$10.33excl. VAT(£8.12)-QuantityMinusPlus
8Spring, Footboard, Return
T2083068
Replaces T2083016
Share this part
AVAILABLETO BACKORDER$3.70excl. VAT(£2.91)-QuantityMinusPlus
9Circlip, Ext 8 X 0.89
T3500207
Share this part
AVAILABLETO BACKORDER$1.67excl. VAT(£1.31)4QuantityMinusPlus
10Bank Angle Peg
T2080780
Share this part
AVAILABLETO BACKORDER$8.17excl. VAT(£6.42)2QuantityMinusPlus
11Heel Plate, RH
T2081455
Share this part
1-3IN STOCK$68.44excl. VAT(£53.81)-QuantityMinusPlus
12Bolt, RHHF, M6x1.0x12, S/S
T3203115
Share this part
AVAILABLETO BACKORDER$1.83excl. VAT(£1.44)1QuantityMinusPlus
13Cover, Brake Reservoir
T2083014
Share this part
AVAILABLETO BACKORDER$17.12excl. VAT(£13.46)-QuantityMinusPlus
14Domenut, Locking, M6
T3350088
Share this part
IN STOCK$1.06excl. VAT(£0.83)1
#PartStockRRPQty
Used
Basket
1Footboard Classic Kit
A9758083
Share this part
AVAILABLETO BACKORDER$394.01excl. VAT(£309.78)-QuantityMinusPlus
2Cover, Brake Reservoir
T2083014
Share this part
3Foot Control Mtg Assy, LH
T2083008
Share this part
4Foot Control Mtg Assy, RH
T2083010
Share this part
5Pivot Pin Dia 8
A9750013
THIS PART IS NOW OBSOLETE
Share this part
NO LONGERAVAILABLE$7.87excl. VAT(£6.19)-
6Circlip, Footrest
T2081417
Share this part
IN STOCK$1.67excl. VAT(£1.31)-QuantityMinusPlus
7Bank Angle Peg
T2080780
Replaces T2080362
Share this part
8Footboard, Die Cast, LH
T2083000
Share this part
9Footboard, Die Cast, RH
T2083001
Share this part
10Rubber, Footboard
T2083006
Share this part
11Brake Pedal Assembly
T2023452
Replaces T2023453
THIS PART COMES SUPPLIED WITH THE PEDAL RUBBER.
Share this part
AVAILABLETO BACKORDER$107.07excl. VAT(£84.18)-QuantityMinusPlus
12Brake Line Assy, Hard
T2021202
Share this part
1-3IN STOCK$61.81excl. VAT(£48.60)-QuantityMinusPlus
13Washer, 15.2 x 10 x 1, Plated
T3550229
Share this part
IN STOCK$0.66excl. VAT(£0.52)4QuantityMinusPlus
14Bolt, Shld, M10 x 1.25, S/S
T3330651
Share this part
AVAILABLETO BACKORDER$7.77excl. VAT(£6.11)-QuantityMinusPlus
15Assy, Gear Lever, Rocket
T2081536
Share this part
AVAILABLETO BACKORDER$119.22excl. VAT(£93.73)-
#PartStockRRPQty
Used
Basket
1Footboards/Rocker Lever Kit
A9758081
OBSOLETE
Share this part
NO LONGERAVAILABLE$190.71excl. VAT(£149.94)-
2Foot Control Mtg Assy, LH
T2083008
Share this part
3Foot Control Mtg Assy, RH
T2083010
Share this part
4Pivot Pin Dia 8
A9750013
Share this part
5Circlip, Footrest
T2081417
Share this part
6Spring, Footboard, Return
T2083068
Share this part
7Rubber, Footboard
T2083006
Share this part
T2083000
Share this part
T2083001
Share this part
10Brake Line Assy, Hard
T2021202
Share this part
11Washer, 15.2 x 10 x 1, Plated
T3550229
Share this part
12Assy, Gear Lever, Rocket
T2081536
Share this part
AVAILABLETO BACKORDER$119.22excl. VAT(£93.73)-QuantityMinusPlus
13Brake Pedal Assembly
T2023452
Replaces T2023453
Share this part
14Instructions
A9900016
Share this part
NO LONGERAVAILABLE$0.00excl. VAT(£0.00)-
15Bank Angle Peg
T2080780
Replaces T2080362
Share this part
16Sidestand Leg
T2089600
Replaces T2081395
Share this part
AVAILABLETO BACKORDER$103.76excl. VAT(£81.58)-QuantityMinusPlus
17Cover, Brake Reservoir
T2083014
Share this part
18Bolt, Shld, M10 x 1.25, S/S
T3330651
Share this part
19Spring, Footboard, Return
T2083068
Share this part
The accessory only version:
FOOTBOARDS A9758085 Includes Rocker Gear Lever
#PartStockRRPQty
Used
Basket
A9758085
Share this part
NO LONGERAVAILABLE$389.68excl. VAT(£306.38)-
2Footrest Bar Assy, LH
A9750244
Share this part
AVAILABLETO BACKORDER$132.49excl. VAT(£104.17)-QuantityMinusPlus
3Footrest Bar Assy, RH
A9750245
Share this part
NO LONGERAVAILABLE$132.49excl. VAT(£104.17)-
4Pivot Pin Dia 8
A9750013
Share this part
5Circlip, Footrest
T2081417
Share this part
T2083068
Share this part
7Rubber, Footboard
T2083006
Share this part
T2083000
Share this part
T2083001
Share this part
10Brake Pipe Assy, Hard
A9620002
Share this part
AVAILABLETO BACKORDER$11.24excl. VAT(£8.84)-QuantityMinusPlus
T3550229
Share this part
12Gear Lever, Rocker, Finished
A9733506
Share this part
AVAILABLETO BACKORDER$27.02excl. VAT(£21.24)-QuantityMinusPlus
13Brake Pedal Assy, Footboard
A9733507
Share this part
NO LONGERAVAILABLE$21.09excl. VAT(£16.58)-
14Instructions
A9900016
Share this part
15Bank Angle Peg
T2081409
Share this part
AVAILABLETO BACKORDER$7.85excl. VAT(£6.17)-QuantityMinusPlus
16Loctite 242 0.5ml
A9910014
Share this part
NO LONGERAVAILABLE$4.30excl. VAT(£3.38)-
