HansO
Not Taking Life Too Seriously
- Joined
- Apr 4, 2010
- Messages
- 13,447
- Location
- Batemans Bay, NSW, Aus
- Ride
- 08 Rocket III R.I.P now TEX Triumph Explorer
just a tip, I use Selley's 401 hi temp silicon, it is a sealant and adhesive silicon. I put only a smear on the sump plug washer surface and washers (after both have been degreased) but as I said only a smear you do not want any on the threads and dont even think about putting any on the O-ring, then tighten them up till they seat plus a little nip up, not enough to squash the crush washers much but tight enough so they will not readily come undone take it for run to bring up to temp then check the next day, have not had a leak yet and it makes the crush washers last a lot longer
you could also use another brand of gasket silicon but I use Selley's 401 as it is readily available and can also be used as an exhaust joint sealant, also some bike shops use it as it is also cost effective
