CaptainCaeruleus
- Joined
- Dec 24, 2005
- Messages
- 205
My dealer was getting ready relocate my coolant bottle underseat today.. Mind you my bike is his first experience with the kind of R3 performance mods done on this forum. He had two questions:
1) First he was concered about the system's ability to draft coolant through the longer hose... I said no problem... At least a dozen guys have done this and run thousands of miles with no problems.
2) Right now the bottle is above the radiator and provides gravity feed should the cooling system develop a leak and loose the ability to siphon from the bottle. If the bottle is underseat, it will be below the radiator and may loose its ability to feed the cooling system in the event of a leak... He bounced this off of his Triumph Engineering Support guy (Atlanta I guess) and of course he didn't have an answer either (no surprise)... Support guy also stated he didn't know wether or not there would be a warranty issue if the bottle was under the seat and a problem as described above developed.... He said he would be most comfortable if the bottle was placed where gravity feed would be provided... Well I sure as sh&%t ain't gonna mount it on the handlebars.... What we are looking into is an alternative bottle from an old Triumph Trophy my dealer has in the shop. It appears it may fit under the tank where the air ducting was removed for the Unis... We will try this on Monday.... So bottom line, do you guys think this gravity feed thing is a ligitimate concern or not...
Thanks,
Mike....
Thanks,
Mike....
