If your R3R a real model 2012 is (model up to VIN # 574812), use the map for the production silencer (20352), for the aftermarket silencers e.g. TORS, please use the map 20355.
Now load the PC-V zerro-map on the Power Commander-V.
Now put the adaptation with TuneECU back and start the engine, let the motor run at idle until the green "TPS light" in TuneECU appears. In this process, do not touch the throttle.
If you reset the Adaption want to perform with the 12 Mintuten Tune, they proceed as follows:
1. Ensure the transmission is in neutral.
2. Ensure the ECM has no stored faults (DTCs).
3. WITHOUT TOUCHING THE THROTTLE, start the engine and allow it to warm up to 90°C (Coolant temperature) .
4. Leave the engine to idle for a further 12 minutes. Now have fun.
Does your bike a VIN greater as 574812, then it is a model 2013.
For this model with production silencer, the map "20685" is required.
For this model with aftermarket silencers e.g. TORS, the map "20688" is required.
Download sources:
PC-V zerro map:
http://www.powercommander.com/downloads/21-003/maps/M21-003-000.pvm
20352map:
http://www.tuneecu.com/Tunes_in_Hex...model/all_Rocket/Rocket_Roadster/20352Map.zip
20355map:
http://www.tuneecu.com/Tunes_in_Hex...model/all_Rocket/Rocket_Roadster/20355Map.zip
20685map:
http://www.tuneecu.com/Tunes_in_Hex.../Rocket_Roadster_from_VIN 574813/20685Map.zip
20688map:
http://www.tuneecu.com/Tunes_in_Hex.../Rocket_Roadster_from_VIN 574813/20688Map.zip
I hope it helps you.
BR, Tom
