GavinHooper-Newton
Aotearoa New Zealand
2008 Rocket 3 Touring
Has anyone ever used Unifilter (go to bottom of page) foam filters for a triple filter setup. Currently have short pipes standard air box. Installing a set of pipes Paul Bryant has de-cated for me and was going to go K&N ru2780 but toying with idea of foam? Ramair is stupid expensive to get shipped to NZ. Have tuneECU and de-cat with air box delete mapping to install to replace current map for short pipes standard air. 08 R3T
The intake tract filtration isn't as important to engine air flow as the exhaust. One type over another is at best only slight marginal gains, so go with what makes you happy. The exhaust system is the key to big power gains, not intake until you add boost. I had the K & N's on my 05 Standard and was very happy with that setup because they could be easily cleaned.
The unilters work.
