transmission noise!!
Ok so I could not get a 16 mm or 5/8" on her so she must be 17 mm which I got the box end on. Reach thru and bend of the wrench face out word.
I did not remove the battery box. The motor has just enough room to slide past. Just go slow and make sure no wires get trapped.
I had a decent night sleep . will look at how I can get a spanner past the obstacles enroute to the nut and we will see. now how about a picture of you in skivvies wrenching!!
ok jake I will look this morning on how to get past the horizontal post in order to get to that nut
The answer to your problem is yoghourt.
I like yoghourt and when I am finished I wash and store the plastic containers. When working on a bike I use different ones for each assembly or area of the bike e.g. all the nuts and bolts for the rear wheel and final drive go in one. When it is time for reassembly you don't mix stuff up. HTH
P.S. strawberry is really good on cereal....
Myself I use coffee cans which now days are plastic. Lable the outside with a permanent marker!!!!
you guys are too much . I use large plastic garbage bags and dump everything in there ..............
just pulling your rusty drive shaft , to each his own I tape everything with masking tape and write what they are for or once the part is removed I screw back on the fastener on that piece, and when needed where complication are present I take a picture . so far I have no loose screws nor fasteners lying around .but to keep all odds in my favor I also bend down every day at 5pm facing mecca and pray to Allah ..to keep my work on track . Please mister spy from NSA just kidding!!
Ziploc bags and a sharpie...been using that method for years. I label the bags and put everything in a small roll away tool box. Lots of pics...digital cameras make the process a lot easier
a little prayer to the triumph god would not hurt
