xlr8tion
Turbocharged
The Avon is the most expensive option for the front tire and by some accounts it isn't the best choice for wet traction. I haven't tried it, so I can only go by the dozens of comments here and on the .com site. With the professional research and opinion of one of our most knowledgable users here (IMFASTTOO- a lifelong member of the motorcycling industry) I was the first to try the B'stone Exedra Max for the rear and several other tires for the front.
If you are a performance and/or handling-oriented canyon-carver or backroads/twisties traveler I'd recommend either the Michelin Commander II 140/75 17 or a matching Exedra Max in the 130/70 17 size for the front wheel. Either of those choices will lighten up the overall feel of our nearly 800 pound beasts considerably, dramatically improving turn-in, tracking and low speed maneuvering. Both will make our bruiser cruisers feel 100-200 pounds lighter overall and each adds immeasurably to the "flickability" of an R3.
Personally, I slightly preferred the Michelin for its marginally more planted feel tracking through turns, but have stayed with the Ex Max 130 due to the additional nimbleness it affords me, an aggressive rider who values the added quickness and responsiveness in turns and transitions. The only knock I have against the 130 is that with the 200rwhp I have, it tends to float or dance around a bit on hard straight line acceleration, so you need to know its limits there, but even more so if you're adding in any considerable lean angle.
Bridgestone Front Exedra Max 130/70R-17 Blackwall Tire - 004829 Motorcycle Goldwing - Dennis Kirk, Inc.
Michelin Front Commander II 140/75VR-17 Blackwall Tire - 49944 - Dennis Kirk, Inc.
BTW, that's a great screen name you have, xlr8tion.![]()
Phil....
THANKS!
You are a LIFESAVER with that info.....I am not going to be tearing it up and Dennis Kirk has the pair of Bstones for 270 shipped 157 rear 92 front(for the 130).
I am just going to be doing average riding 85 per cent of the time and 15 per cent moderate.
So knowing that...Would you recommend the Exedra Max 240/55 ZR16 in back and the 130/70 zr17's on the front......I am going to be doing moderate riding at most so I am WAAAY below your riding skill set on this bike....Will be doing 90 percent 1 up 10 per cent 2 up
Regards....Greg
PS..Thanks again...These dealers are killing me! None will allow me to bring online tires in so I have to get bent over...Not a prob if they have the correct sized tire and speed rating I am looking for.....
