Tickover problem
Rocket33
Standard Bore
Rocket Roadster
Hello!I've got a Roadster with Ramair and Zard exhaust.When I got the Ramair did the install and tick over set up.After set up all good,but experienced flat spots when accelerating so decided to have bike Dyno tuned.Dyno tune done with good results but tuner said tickover over had been a problem?Rode bike good smooth accelerating in all gears and chart result looks great.Tickover is ****e though,fluctuating and cold start need to rev bike to stop it dying.Tuner says probably tickover sensor at fault,whatever that means.Pulled tank off and going to check plugs and coil connecters.Ramair filter looks OK and filter sensor seems solid.Any other tips or suggestions greatly appreciated.Thanks Mark.
It is customerry to introduce yourself and tell us a little about yourself.
Yeah sorry.Been riding since I was 16,I'm 67 now.Been through all the super bikes as well as 3 Harleys.Love the Roadster,current ride.Once she's set up right I'll be even happier.I'll change both the TPS sensors and go from there.Hopefully that will sort out the tickover problem.Cheers.
