spark plugs position
on a plug test on fast fours mag when fitted new plugs to begin the test they found new plugs produced 1 hp less power so maybe the rounded warn plug worked better and the long life plugs did not perform the best but the cheapest copper core ones produce the most power
One cylinder out?!
You, M8, have no sense of speed and power!
When I was racing half midgets, a change of sparkies usually made a .1 to .4 second lap time difference in EITHER direction!
So, go figure.
Come on guys is this April 1st or something? When cruising the plug is firing at least than 1 second intervals. The mixture in the combustion chamber is a compressed gas which will ignite with one spark and we have two!
The bike has fuel injection monotired at many times more than that with sensors to make sure only the correct amount of fuel that can be burnt is injected.
Weight has got to make more difference surely? Therefore shouldn't we be arguing if we've taken a pee or had a dump before we go out if the power to weight ratio has made a difference? Will that difference be greater than point gnat's *****of a horsepower?
Indexed toward the intake for split second advance on the combustion.
To quantify the improvement, "point gnat's dick" would be an appropriate gauge.
Yep this vid confirms my thoughts not .1 hp but 1 to 2 hp wow so I take a dump take a piss (not that I'm taking the piss out of any one) and since I only weigh 62 kg I say I should have an advantage
