smooth lower end torque
Wow, this is a nice thread. I have some specific needs for the low end low velocity portion of the throttle twist.
A TPS vs RPM analysis is easy to do. Even in your head. If you want graphs then get a cheap ELM27 type plug for the OBD connector and log the data to a cellphone. Logging AFR requires more specific equipment.
If I'm in top at under 2000rpm then I don't expect instant response. And would probably drop to 4th unless the transition upwards again was likely to be gradual. Like Fred - I try not to lug the engine.
1st for me is a crawler gear - I live on a rural estate with really ****ty roads - speed bumps etc. 5th is tuned as a distance and economy (ish) gear.
For interest and delectation - here is a graph of a recent run. A mix of rural roads. About 45minutes worth. The log file ran out as I hit motorway.
If I remember to hit the button today I will have a "mostly motorway" run I can share.
As stated by 1K9, this is an interesting thread and part of what makes this forum exceptional.
Good to hear, im waiting on my paul byrant header. Cant wait!!!
Same. I have the complete system
