Dean0
.060 Over
G’day all, it’s been some time since I was last here.
I decided it was about time I got more acquainted with my R3T, what better way than to tackle the 48,000km service, starting with the valve clearance check.
In 0.125 0.095 0.125 0.165 0.152 0.152
Ex 0.205 0.215 0.245 0.245 0.145 0.245.
After installing 10 new shims and re installing the cams I went about setting the valve timing. The procedure of setting the timing marks up using the jig is straight forward enough but as pre advised, it’s all down to the point where the cam tensioner is installed. After numerous attempts, I just cannot get the timing marks to line up perfectly after rotating the engine four times.
I’ve had advice and encouragement along the way from my good friend afar, he is a wealth of knowledge and experience with the R3 engine, be it highly modified with dialled in cams, but he has never set an engine to stock timing marks.
Other advice has said that it is normal for the timing marks not line up perfectly due to stretching in the timing chain. I have already verified the chain is in spec and good.
Having done a thorough search of the forums I find very little on the subject.
I would greatly appreciate any help or advice from others that are familiar with setting the valve timing on a stock engine.
On upside, I did manage to measure the final valve clearance.
In 0.125 0.115 0.125 0.120 0.127 0.127
Ex 0.185 0.185 0.180 0.185 0.180 0.180
Dean.
Dean.
