Rocket__88
Space cadet
England
2011 Triumph Rocket III Roadster
Hi guys, the rear tyre valve has warped slightly on my 2011 Roadster. I have had to use plumber's PTFE tape as a literal stopgap, until part number T2006615 arrives. My question is, how difficult would it be to deflate the tyre, partially remove the tyre from the rim, while keeping the wheel in place on the bike, to swap the defective valve with a new one, then get the tyre back onto the rim and reinflate it? I’m moderately technically proficient. I’ve never removed a motorcycle tyre, but I’ve replaced countless bicycle tyres. Or, should I get my friendly local mechanic to do it?
First up I'd really advise not to ride the bike with a suspect valve, if it were to break off completely while you were doing a decent rate of knots, loss of control is almost guaranteed because of the sudden deflation.
Wheel off, tire off, then replace the valve.
I guess you could replace the valve with only 1 side off the rim, but why would you? There'd be 1 hell of a lot of mucking around trying to do it like that, the 2nd side is easy as to take off, and, as the first side to put on, it's easy too.
Thanks for the reply. The stopgap is just to keep the tyre inflated enough to make it easier to push the bike onto a trailer, if necessary, for the 2 mile journey to my local bike mechanic's. I don’t feel technically proficient to remove the rear wheel completely and then reinstall it totally correctly, which was why I was asking how difficult it might be to replace the valve myself, with the wheel still on the bike.
I really covet the single sided swingarm on the newer models. 😆
@Kiwicol is spot on. Even if you have the means to do it yourself it would probably take 10X the work and effort to do it that way.
The rear tire is notoriously difficult to remove. DIYers often have to cut the bead to get it off.
The wheel comes off easily and then you'd have a much easier time working off the tire. At this point you could just remove one side of the tire to get to the valve. Traditional tire irons are not the way to go and, in my experience, a lot of shops will mank your rims up using their hydraulic machines improperly.
I do my own tires and have found an easy system- if you're interested (see below). For balancing the rear I use dyna beads.
My technique is better now and it takes very little effort using this tool....
I would recommend if you're doing it yourself you take the wheel off. There is no drop in the rim like on a car wheel so getting the tire off manually requires a herculean effort, however since you only need to replace the faulty valve you can break the bead on one side and collapse the tire far enough to access the valve stem nut. There is an O-ring that can be easily damaged leading to leakage so don't twist the stem once you have any pressure on that O-ring. I had a (very) large C-clamp I used for doing tire changes that worked for this kind of project (originally bought for removing intake/exhaust valves from a Yamaha XS1100). The absolute easiest way to get it done is take your wheel (and new parts) to a tire shop with pneumatic equipment and have them install the new stem and test for leaks after.
Because the center of the rim is narrow it pays to have some blocks (made mine from a 2x4) 3 to hold the tire bead in the middle when trying to remove the bead.
i kept trying to tell a professional until he was wore out (twenty or thirty minutes) then i told the manager and wow it worked i got a lot of apologies because he would not listen to the old guy.
If a "professional," then I take it that he was using a hydraulic machine and still struggling. This is where your rims get marred up and then they point to the sign that says....
I had numerous shops scratch my rims using these brute force machines (improperly).
With the right technique it actually takes very little force to remove and mount the tire using a https://www.mojotiretools.com/mojoweb.htm (Mojo Lever). The key is to keep pushing down behind the tool to keep the tire in the narrow part of the rim that you mentioned.
