Rocket running poorly, suggestions welcomed
Jim,
Very glad you be OK.
That stock taillight by itself is inadequate and dangerous, IMHO.
Add more and brighter lite!
This was taken before it really got bad. Frogg Togg time
Yes, I was thinking of your setup when I checked mine at the bar.
I usually don’t ride much at night but will consider some LED upgrades.
He had no business going that fast in the right lane of a three lane highway as there was also standing water.
Several cars were pulled off with flashers on and all but one other biker were stopped under bridges.
I felt the front hydroplane a few times but the Michelin Pilot 5 held its line.
Hanging out at his clubhouse was fine but not for me.
Finding it proved difficult in the rain as they aren’t allowed to tell anyone the exact address, had no signage, and it was hidden
in an alleyway.
25k isn't much on plugs, I eat my words, I'm really surprised it was only plugs
I had a '77 Pontiac Bonneville with the same issue... That V-8 engine did the same thing every 12 months like clockwork... and changing the plugs worked every time.
-MIG
Glad to hear it all worked out... Good to know If I find myself in a similar situation I've got the folks here to lean on if needed...
-MIG
I finally changed the plugs in my Dodge Magnum Hemi at 150,000. It was running great but I was afraid they might be rusted in. I figured they would be iridium but they were just standard plugs. Put in a new set of the same kind. Got them on sale, less than a buck apiece. I think if an engine is tuned correctly plugs will last a long time.
There was a time when plugs weren't changed. When I first got into the trade we had a plug cleaning station at the GM dealership I worked in. By that time, it was rarely being used since selling new plugs was more profitable. If you look at a plug, there's not much to go wrong so long as the insulator and electrodes are ok. We cleaned, did a visual check, gapped them, then reinstalled and the vehicle ran like new. I used to use it to clean the plugs on my older snowmobiles that were often oil fouled. Today, those cleaning machines are rare collector items and are highly sought after.
I've got close to 50,000 kms on my plugs and still haven't changed them. New ones are ready to go but they look good, gas mileage is still ok and engine runs fine. I might change them in the spring to see if I can notice any performance change.
I think modern engines with fuel injection and high power ignition systems will run great on plugs that would misfire on an old engine. I used to keep the battery in my Kawasaki 500 all winter. It has a 60,000 volt electronic ignition. I could put fouled plugs that wouldn't fire at all in my snowmobile in it, and it would fire right up. I'd let it warm up, then put the plugs back in the snowmobile.
