Hi all, I had my brand new Rocket 3R for 6 days and done 270 miles. I’ve had the usual KEY FOB OUT OF RANGE issue. Dealer said “never heard of that before mate”
It has CUT OUT on me at low speed coming up to a junction.
Dealer says “ there’s no fault codes on it. It’s not as complex as a car ecu mate”
Then MAJOR FAULT- I got caught in a light shower (should be able to do this in the Uk) The bike tried to START ITSELF. Key fob in the house and turned off. Bike turned off with kill switch in the off position, clutch not pulled in. No lights , dash, anything.
It made a noise, when I returned to see what was happening, it did it again, obvious to me it was throwing the starter motor in for a split second. Then I started to video it. It did it for a third time, then to my amazement it pulled the starter motor in and turned the engine over for about 30 seconds. It stopped for a few seconds, then pulled in again and the starter was turning the engine over until I got my spanners out and disconnected the battery. After retrying to connect the battery the starter was engaging, it kept doing this for about 4 hours. Until it dried out.
After that time I could have the battery connected without a problem, the ignition / clocks ect would come on, kill switch on, fuel pump up to pressure ok, and run as normal. It was working normally when the dealer picked it up.
They’re telling me that the starter solenoid was stuck in. ??
I honestly can’t believe this, as it would have been turning the engine over constantly, not intermittently, and how the F did it do this when the bike was parked up, turned off, with the keys in the house.
I’ve emailed Triumph UK, but not heard anything back.
Dealer is also saying it’ll be over a week, because Triumph UK haven’t got any starter solenoids in stock?
I have Video evidence of all if this.
Wish I’d read all these forums before buying. I’M GUTTED
Also have way too much oil in mine too, well over the MAX line.
