ReverseGreen
Standard Bore
2005 Rocket iii
So I have been having issues with the clutch on my 2005 rocket 3. I had the clutch lifter piece friction weld to the shaft and shear off. I suspect the clutch wasn't entirely disengaging. I have since replaced the lifter piece, lifter piece bearing, lifter shaft and pressure plate to upgrade that system to the newer models that fixed some issues of the original design. I also replaced the clutch cable with the barnett clutch cable as well as a full oil flush incase of metal particles. I'm still running into issues with the clutch not disengaging. I saw some heating on a couple of the steel plates in the clutch and I'm trying to figure out if it's time for new clutch plates or if there could be another issue. There isn't any notching on the clutch basket it still looks brand new. If I have to swap plates I'm looking to replace all of the plates with the Barnett upgraded plates. Anyone have any insight into this issue or the barnett upgraded plates?
