Replacement Grips
sds
.040 Over
2014 R3R,
Hello,
I am looking to replace the stock grips on my 2014 R3R. I have had Kurakyn Isogrips on my other bikes. I would like to use them on the R3R.
Has anyone here used them,and which do I need. I typed my info into their website, and only the chrome ones came up but were listed under the touring model.
Thanks for any help.
sds
Just removed black ISOGRIPS from my Rocket. You don't need anything other than the grips themselves. You'll have to slacken off the throttle cables at the injectors otherwise it's a straight swap over.
this is what i did to stop the left had side one sliding off.
I had the grip sliding so I removed the 4 alen screws and drill taped the end cap the handle bar is already threaded .no more issues with grip moving 20141101_140844.jpg
I used stainless steel screws and i nicked the screw to use it to tap thread into the end cap as the tap point was too long before it would start to tread the hole , you only have 4 mm to work with
Ordered the grip buddies today. Figured for the price they are worth the price. If they do not work for me I will try another option. sds
I did the same. We'll soon see if they are worth a $hit.
They were inexpensive at any rate.
I just spoke with a rep. at kurakyn, they only have one model and color(chrome) to fit the 2014 R3R. Not sure if this applys to all years. sds
Pray tell, and which are those?
