Removing cylinder head
m6w6
.040 Over
Neufeld an der Leitha, Austria
2009 Touring
Hey there!
Is it possible to remove the cylinder head with the camshafts still attached while the engine is still in the bike?
Or asked differently:
What MUST be removed from the bike/engine to lift the head?
Thanks in advance!
Idaho Red Rocket 3
Nampa, Idaho
2006 R3 Standard Bagger w/Fairing
Cams MUST come out to remove/install head. Can be done with engine in frame. Currently have mine off for performance enhancements.
There is a ton of parts that have to come off to get the head off. Gas tank, intake plumbing, oil tank, throttle bodies, exhaust, radiator, ect...
m6w6
.040 Over
Thread starter
2009 Touring
Do the cams also have to be removed if the engine will be detached from the frame? Everything else sounds kinda reasonable -- except, the oil tank? Really?
idk
Maryland
Royal Enfield Bullet
The frame can be removed from the engine without even taking the rocker cover off. Instructions are in the manual in my signature.
R-III-R Turbo
Mine is the biggest :)
Ireland
2.5L Stroker Rocket III, Hayabusa
Cams have to come out to get to the head bolts.
Oil tank does not need to come off to remove the head, even when block is still in frame, contrary to the manual. Might be a shade easier without the oil tank in the way, but it's not necessary.
Can be done with engine block still in frame.
Frame can also be lifted off engine without opening engine.
What is your objective?
R-III-R Turbo
Ireland
Investigating damage caused by an apparently slipped chain :banghead:
Well the good news is you can check cam/valve timing before removing the head, only the cam cover and crank nose inspection port cover need come off the engine to check timing.
I'd imagine if you find that timing is still correct, then there is no need to remove the cams or head.
You can also check chain tensioner drop as per the manual, except with a calipers instead of the Triumph tool. Only need to remove the big centre nut.
Anything more than 16mm drop and the spacer is needed to restore correct tensioner spring pressure.
If the tensioner was not holding up for whatever reason, the chain could jump teeth or 'slip'.
What are the symptoms of the problem?
Curious as to why someone suggested an apparently slipped chain.
m6w6
.040 Over
Thread starter
2009 Touring
That's my suggestion, unfortunately.
Measured no compression at all. Tensioner measured fine, but I'll redo and post numbers. Bike did less than 20K km.
I have to verify a third time, but this is the timing at TDC:
R-III-R Turbo
Ireland
Hard to tell from the angle but if the crank is indeed at TDC on #1, that does look well off.
Wonder what caused the timing to become incorrect.
Did this happen suddenly while riding along, or...?
m6w6
.040 Over
Thread starter
2009 Touring
Coincidentally (?) 2km after jumping a big bump in the road.
The tensioner measures 19,2mm/54,7mm now, while I'm pretty sure it measured 53,3mm the first time.
Yes, TDC, it should be:
AdBlock Detected
I've Disabled AdBlock
