Removing cylinder head
idk
Maryland
Royal Enfield Bullet
No compression? Did you remove all the spark plugs to do the compression test? :rolleyes:
R-III-R Turbo
Mine is the biggest :)
Ireland
2.5L Stroker Rocket III, Hayabusa
So it ran for a period after the event, albeit very poorly?
Since the tensioner is well over the 16mm drop, I wonder is that enough to let the chain jump teeth.
Could you try set timing again, put the spacer into the tensioner, and assuming it turns over (by hand initially) ok, see if compression returns and it runs ok?
Before taking the head off.
Gerald
Lou. Ky
05 Rocket 3
If checking compression, only take out one plug per cyl., and tie throttle wide open.
Idaho Red Rocket 3
Nampa, Idaho
2006 R3 Standard Bagger w/Fairing
That's my suggestion, unfortunately.
Measured no compression at all. Tensioner measured fine, but I'll redo and post numbers. Bike did less than 20K km.
I have to verify a third time, but this is the timing at TDC:
Why do his cam gear bolts look like that ? Mine have button heads. In the picture it looks like the lower bolt on the far gear is backing out.
m6w6
.040 Over
Thread starter
Neufeld an der Leitha, Austria
2009 Touring
It ran just normal, AFAICT, just 90 km/h hill down when it went out.
I can breath through the cylinder with valves "closed".
wjb
Turbocharged
California Central Coast
2008 Rocket III Touring
If you can breath through the cylinder with valves closed, that sounds like a major malfunction! If you blow into the cylinder through the spark plug hole where does the air go? Can you hear it escaping through the throttle bodies? Exhaust? Crankcase breather? That would help narrow down the problem.
AdBlock Detected
I've Disabled AdBlock
