Rebuilding the Trike
more plumbing work and fitting a high power 2 way solenoid for reverse to remove lever.
Could you give us a little more detail on the solenoid for the reverse. I'm looking to do something for my trike also.
It is a friend who gave it to me it pushes and pulls, he has a spare ill ask him if he wants to part with it, I am going to use the light switch from another triumph and insert that into the blank on RH controls with two relays to operate one for reverse the rh position on switch the middle to engage forwards and the right position to de energise both relays as the reverse box is lightly spring loaded to remain in forwards position.
Side lights, reflector installation on rear and starting work on new front fairing.
Working on new fairing design, I am going with one of the two headlights with two high beam smaller lamps either side plus a new location for indicators.
