Rebuilding the Trike
Pablouk
R3Triker
YATELEY, HAMPSHIRE, UK
2008 Rocket 3 with 2015 motor
Rigid axel gone, now full IRS, used a plethora of TVR parts. Thanks to help from trikeshop in Cardiff.
Pablouk
R3Triker
Body is coming along sl8w but will be done by winters over. When done and painted I might actually get around to fitting the keyless kit that's been on the shelf ages.
Pablouk
R3Triker
Still working on it, got cable operated latches to open boot, but in will change to solenoid set up later. Not sorted lights I was thinking of putting them in the venturi opening. I'm going to fit two radiator setups one in each venturi at front opening and remove the existing radiator from front end. I asked Triumph if it was possible to switch around the return feed and blank on water jacket at the back of the block. They could not answer. You guys got any ideas?
