Dawg68
Nitrous
Thank you 1olbull.....fully understood now. I ran out and traced where the original breather hose ran... I see.
The hose runs strieght into the air filter housing and as everyone said, once you remove the tubing it leaves the hole open to whatever comes into the filter box. Got it.
So you left the original hose attached to the crankcase breather and you put filter foam into the hole where the tube connects to the original filter box. Good idea I will do the same.
I'm glad I checked the Ramair crankcase filter as it was starting to crack where the clamp was located.....must be the same rubber as the original air filters....lol. I took it off and reinstalled the original hose.
Thanks fellas!
Thanks fellas!
