Pete
Life's a Beach
I used a 3/4” hole saw to drill a hole in the opposite position to the air sensor on the Ramair and machined up a two piece nylon fitting that I glued together with loctite “all plastic” polypropylene glue to form an elbow.
I based the elbow fitting dimensions on the ramair air sensor and allowed for a 1/2” inside diameter hose.
Then connected the crankcase breather to the ramair filter by routing up the rear of the motor and forward under the tank.
Photos attached.
Then told the missus the motor was buggered and we need to start saving for an engine rebuild with upgraded Ho to make it stronger
