R3 GT Tune ECU question
Stan
BigPapa351
Melbourne Australia
Rocket 3 GT
Hi all
Had some issues on a dyno with the bike
Long story short i did an ecu recovery at home and bike is running ok now.
However everytine i try to load All unrestricted map feom my phone, the ecu and phonenconnection fails and i have to use another device to run reovery.
So i tried loading unrestricted map from my other android device , but i cant load it to tuneecu app. I can only download one that it allows me (standard map)
Also today after doins ecu recover the fuel gage went to 0 then i sarted riding and it went to 300k range and shows as full.
When i tried to open the fuel cap, some fuel came out under pressure.
(I assumed it was just n overflow from overheating after running the bike for 12 min.)
Now fuel is showing a 300k range and full.
Two questions:
1) Is the fuel a sensor issue can be reset in tune ecu ?
2) how do i load unrestricted maps on my android device( not a phone))
All help much appreciate it.
Thanks
The Penner tunes are in zip files on Tuneecu.bet, custom 3/4 cyl maps. You could email the Penner zip file to yourself and save the attachment to your download folder. Then unzip the hex file. Open it from the download folder then save it under your Tuneecu maps.
@Stan what issues did you experience on the dyno and what did they do? things don’t add up. I assume all was well before the dyno?
The fuel gauge has an averaging circuit that resets to zero and needs time to build after an ECU tune. It's not a fault. It has nothing to do with the fuel that came out. I assume that is due to the fuel expanding as it warmed up. I do hear my machine hissing when I leave it in the sun.
