PC5 for 08 Touring
Gearbox
Former Member
Australia
2008 R3 Touring
Does anyone have a PC-v+ on a 2008 Touring. Seems to be heaps info on the net for Roadsters but I can't find anything on Touring models. Looked at Dyno site and it seemed to me that they fit both but I would like to make sure before I purchase one.
A part number and seller would be a great help.
Several guys have them on Tourings and if you are thinking of adding the "Auto Tune"module, drop me a "conversation" (much preferred it when they were called "PM") with your e-mail for a copy of my AFR map if you want, it will liven it up
I have a PCV and AutoTune on my 08R3T. I set it up with a zero map in PCV and Waynes Toruing tune in ECU via TuneEcu. Seems to work fine, I have not had it on a dyno nor looked at trims since installed but like the way it runs.
When I get home tomorrow I can check part numbers.
Much appreciated!!!
I run one on my 2010 Touring, but it was set up by Carpenter Racing, so it's just a black box to me. Nice thing is with the Autotune and the LCD display, you can have a tach, along with a whole bunch of different info.
It is part number 21-003 for 2009 and newer R3's. I think the reason its not listed for the 08 is Dynojet never tested it on one, but it works. Can't help you with a seller as I bought mine used off a forum member.
Cheers for the info. I just had a brief look on the net and some have PCIII listed 05-08 & PCV 09-14, maybe they just want to move out old stock? I'm off Tuesday for a week so I'll have time to surf for a good deal on both PCV & AT. Thanks again!
I wonder if Hanso got my conversation....ooops..I mean PM.
