new backrest and rack and saddlebags
Nah, gonna run it in 30 hours if I can. I'll check weather and try to miss it, later up, try to stay on roads already salted.
Ah screw it, if I can run through hurricane isaac I can do this.
(I think)
Got a brand new tire coming wednesday and a
You gonna have a whole new concept of wind chill. :)
If you pack right ,you can carry everything you need for camping.
Brave camping under trees like that, even for you @Steel.
Where is your chainsaw?
We have a safety song we teach kids from infant ages due to our lethal drop bears.
Playschool's 'There's a bear in there!'
You should Google and listen! ;):D
You mustn't realize that in the new world we don't have all the dangerous and scary critters that y'all have in the Outback. :D
you're probably right. I wonder what the weather will be like around the 26th or 27th. gonna go buy some more layers.
wish I had some electric insoles and glove liners....
Strange you should say that, My unused ones could just make it to you by then.;):D
Go Chinese and ask for express mail.
Electric Heated Shoe Insoles Foot Warmer Heater Feet Battery Warm Socks Ski Boot | eBay
Color, footsize? What more could you possibly need to know?;):D
I never got to Instructions on how to use cause I bolded a few doozies but then read this and cracked up
Working Principle:
  • By the battery output DC (voltage and current) through the temperature control switch regulation directly to the heat carrier at both ends of the cable pressure to the heating carrier inside the heat carrier is pressurized heat energy to convert heat to release.
;):D:roll::roll::roll::roll::roll::roll::roll::roll::roll::roll:
Size:
Large size (L): 40 TO 46
Approx. 31x11x2cm/12.2"x4.33"x0.78"
Small size (S): 35 TO 40
Approx. 27x10x2cm/10.6"x3.93"x0.78"
Features:
  • 1 pair of remote heating insole can be cut.
  • Can be cut according to their insoles size but not cut to the smallest yards or less.
  • With easy to use, high fever temperature, long service life and so on.
  • The use of carbon fiber material, in the power of heating at the same time, carbon fiber issued far infrared, play a role in promoting blood circulation and other health effects.
  • Slim more warm, low voltage, constant temperature heating. Heat a wide area, heat evenly.
  • Waterproof seal design, chips, batteries are waterproof design, do not worry about sweat caused by static electricity, but also simple washing.
  • Heating efficiency, intelligent remote control, electronic control part of the remote control one-to-one control insole transfer, shutdown, high, medium and low three stalls.
Working Principle:
Instructions for use:
  • Connect the cord and charger to the insole.
  • The battery is fully charged before use, the charger is lit red indicating charging, when fully charged, the lights turn green.
  • And then according to their own needs through the smart remote control buttons to adjust the temperature.
Specifications:
  • Product name: Heated Insole
  • Material: Composite carbon fiber material
  • Color: Red, Black
  • Rated voltage: 3.7V
  • Charging time: 4-5h
  • Insole battery capacity: 1900mAh
  • Charge cut-off voltage: 4.2V
  • Discharge cut-off voltage: 3V
  • Battery life: 600 times
  • Charging method: constant current and constant voltage (CC / CV)
  • Input: AC100-230V 40-60Hz
  • Output: DC4.2V 500mA * 2
  • Suitable code number: 39-47 yards
Package Include:
1 Pair of Heated Insole
1x Remote control
1x USB power cord
This is what you'll need for the trip.:roll::roll::roll:
