Wilk I to think there might be some confusion between you and Carpenter Racing. I say this because they have done 2014 Roadsters with Tune Boy and of course the PCV. The confusion might be that They are saying Tune Boy has not built the high rpm map yet for the 2014 and 2015 models. You might want to ask
@IMFASTTOO  to clarify this.  Now can you describe what you got for the 500 bucks you spend on tune boy? I am trying to figure out whether you purchased the standard tune boy or Tune Boy Live. It is easy to tell if you have the full blown tune boy live as it will have a wireless WiFi unit and a innovate wideband O2 system that also hooks into the WiFi box. The box has tune boy label on it but if you look closely it is also produced by Innovate Motorsports. other then that without getting a copy of the map to see if it is corrupted or what type of map it is I can only hope it works out for you.
I will state this the Roadster maps on the TUNE BOY site are empty files and will not open after you down load them. Now the Older Rocket Maps with the early ECU on the site are good maps only to 7000 rpms.
One thing I also do when I am going to use tune boy or tune ecu for that matter is to pull the map up in tune edit or tune ecu the close the program before I plug into the bike.
Good luck
