R3Rx118
.060 Over
Wilmington, Delaware, USA
2015 R3Rx118
Hey guys, this is probably a non issue but I wanted to ask here before doing it. I have the standard motorcycle floor jack and up until now all my bikes have had frame rails to lift from, not so with the Rocket. Is there any issue doing the same thing with the rocket since it will be basically lifting the bike by the oil pan/case? Also do you need some blocks or something to give it a better surface or will it balance fine as is??
rocketjohn
Top Fuel
Roanoke, VA
was a 2013 Triumph Rocket 3 Touring
Jack-Be-Quick | Rocket III (2004-2017)
Bedifferent
Old man on a bike
Coldwater, MI
2015 Rocket 3 Touring
Several posts on this topic. It is not recommended that you lift directly on the bottom of the engine. You may find yourself expensively sorry if you do it. There are plenty of ideas in the numerous posts...including mine.
Rock It
I love to ride
Glenelg South Australia
2012 Triumph Rocket Roadster
For the last 12yeras I have placed a piece of 3/4" plywood with a aunt sally(spinning plate ) attached to it that goes on my bike jack and under the engine I lift it up and spin the bike around so I can ride out of my bike shed instead of backing it out.
So are you saying that it's okay to lift the bike by placing a jack underneath the sump?
ScottishR3T
Glasgow, Scotland
2011 R3T
I lift my touring with this.
I lift from the non side stand side. I have a piece of marine ply on the rear lift bar and it goes under the lifting lugs just behind the engine, this lifting arm takes the vast majority of the weight and the front arm rests under the sump but supporting very little weight.
The bike balances well like this, I jack it up to the desired height then lock the lift in place and strap the bike on 4 corners to it before working on her. Especially important if your removing wheels as this upsets the balance quite a bit :eek:
mstraub72
.040 Over
Leduc, Alberta, Canada
2015 Triumph Rocket 3 Roadster ABS, Black & Red
ScottishR3T, I have the exact same lift, and would f'n LOVE if you took a pic or two with the jack under the lift points you use. My dealer is asking $250 just for labor to swap out the tires, and I'm sure it'd be easy peasy if I can get my 2015 R3R in the air. Scared as hell to damage the sump, as others have mentioned. A quick photo tour of your solution would go a long way for us Rocket newbs. And marine ply...some special type of plywood? Canadian slang doesn't match up. :) Thank you huge in advance.
Boony
Turbocharged
Adelaide, Australia
2010 Rocket 3 Roadster. Black and shiny.
+1 on the Jack be Quick.
Also the Becker Tecknik Rocket 3 lifter maybe useful depending on your requirements.
