It's not popping out like most, wich when they do is a gasket replacement, you may just need to tighten down the bolts, make sure you do that in a left to right - front to back pattern and if loose only use finger tip pressure to tighten and no more than 1/4 turn once you need to use your fist to turn , good luck
