I thought about it, but, the whole process of disassembly, tightening, reassembly is only about an hour job so didn't watch to short cut and already short job and potential slip and damage all my powder coating work
If you are talking about the top nut? You really need the thin wrenches because after you torque the bottom nut you need to jam the top nut and not move the bottom nut so as to over torque the bearings.
JMO
some have had this
most have corrected this with a front tire replace.
we have seen this with metz and avon.
my experience with metz tank slaper if i took hand off bars. wore out the tire (always had a hand on bar) replaced with cobra and now have no problems.
JMO
some have had this
Tires do play a part in the infamous wobble. Either way replacing headstock bearings during this up grade and maintenance round. Have had to adjust my head-stock several times in the last 38,000 miles and believe future adjustment may be futile. Figure as long as it is all apart (installing progressive springs) might as well get it done.
