imcool
Turbocharged
- Joined
- Feb 22, 2022
- Messages
- 540
- Ride
- Rocket 3R 2022
Hello All,
Hope it helps someone
- Stock blinkers are 2watts 12V LED Array in each blinker/turn signal so they are consuming 167Milliamps per blinker.
- When bike is completely OFF and Key Fob is ON and in range then motorcycle drains battery at 80Milliamps.
- When bike is completely OFF and Key Fob is OFF, then motorcycle drains battery at 5 Milliamps.
- Battery on Rocket3R2020+ is 12V 18.9Ah.
Based on numbers above, here is battery discharge duration assuming battery is at 95% efficiency ( Battery at normal temperature etc )
Approximately 160 hours ( 7 days ) to battery drain/low battery/low voltage battery - "When bike is completely OFF and Key Fob is ON and in range then battery drain rate is 80mA."
Approximately 2880 hours ( 120 days ) to battery drain/low battery/low voltage battery - "When bike is completely OFF and Key Fob is OFF then battery drain rate is 5 mA."
