I did electronics measurement and battery drain calculation for rocket3R 2022 - Battery, Turn signals
Just curious how much AMPS the heated grips use. The three settings on high, med and low. The reason I'm curious is when I first had the bike with under 500 miles I was on the freeway at 70 to 80 mph headed up I-80 at a slight 3% incline and the battery light came on. The heated grips were set at high but only had them on a very short time maybe 5 to 10 minutes. I shut the heated grips off and the light went out after about 3 minutes. I was in 5th gear so I wasn't bogging anything down. The battery light hasn't come on since and I did use them a few times usually on and off for a half hour or so but they were on med or low and never on high. Just curious what the AMP draw would be.:thumbsup:
I have one of the older gen Rockets. I installed a voltmeter on my ride so that I could monitor things happening before the battery goes dead. With headlights on and the Triumph heated grips on high, there is no appreciable drop in voltage. I guess it helps that I also have led bulbs in my headlights, driving lights and tail light but even when I had halogens, my voltage never raised a concern. Also, I run my heated grips at least 60% of the time. On some long trips, I never turn them off. They are usually set on the low setting (only 2 on the Triumph grips) with never a problem with battery draw...
Just did a quick Google search and it looks like most grips draw from 3 to 4 amps. Shouldn't really cause a good charging system any problems.
I have heated grips and heated jacket and gloves (grips off with those). So far, no warnings from the bike and a voltage meter on the aux outlet with usb shows adequate levels. I ride 5-7 days a week, so no battery failures yet. Good post/info- thanks.
Hello All,
Hope it helps someone
- Stock blinkers are 2watts 12V LED Array in each blinker/turn signal so they are consuming 167Milliamps per blinker.
- When bike is completely OFF and Key Fob is ON and in range then motorcycle drains battery at 80Milliamps.
- When bike is completely OFF and Key Fob is OFF, then motorcycle drains battery at 5 Milliamps.
- Battery on Rocket3R2020+ is 12V 18.9Ah.
Based on numbers above, here is battery discharge duration assuming battery is at 95% efficiency ( Battery at normal temperature etc )
Approximately 160 hours ( 7 days ) to battery drain/low battery/low voltage battery - "When bike is completely OFF and Key Fob is ON and in range then battery drain rate is 80mA."
Approximately 2880 hours ( 120 days ) to battery drain/low battery/low voltage battery - "When bike is completely OFF and Key Fob is OFF then battery drain rate is 5 mA."
This makes for a good argument as to why you should use a trickle charger during the winter months. Thanks for the info thats pretty interesting.
I like being able to see draw 24 7.
