camccardell
.060 Over
I've done a lot of work modifying diesel engines and doing diesel swaps. Turning the triumph into a diesel would require a TON of work. Totally new head design. Not enough meat for a injector to screw in. Would need a timing cover or a cog bet driven injector pump. Mechanical or electronic injection still needs hard fuel lines and a pump.
The clutch and drive line would fail soo quickly...
Honestly a 900cc turbo diesel would be more than enough. 100-150hp and 200-350ft lbs
Weight will be a killer. Hands down. Maybe a 2 cyl with a external trans. A 4 cyl vw might be possible... I dunno if the frame could hold it all though. I've witnessed a lot of custom diesel bike builds and the frames are always huge!
I'd be willing to attempt to modify a r3 block. Send me one and a blank check and I'll make something happen! Sleeve it down big time, Custom crank, rods, and pistons...
Different cams. Custom clutch basket, plates and steels...
It would be a hell of a 1 off for sure.
There are cruisers in Europe that I are 100+ mpg diesels in I have read about. Might be a whole lot cheaper to import one of those.... Even for just a engine swap!!!
Just looked at some charts and did a piston comparison... It was hilarious. add .090 or .120 sleeve, plus domed pistons with the stock stroke reduce cylinder capacity to 1.67L
Spark plug holes cannot contain an injector, and cam bosses are in the way to center a new injector hole... Lots of weld filling and maybe reducing the valve size might make it possible... That would be the biggest hangup. Ideally you want a flat head anyway with the combustion chamber in the piston. So unless there is a similar head out there... $$$
I loved reading this thread though. If anyone care to attempt this feat of engineering, I want in!
