How would one make a diesel rocket?
Link Removed There you go, get busy
You Renegades, I can imagine an 'Orange County' style (Yucchh!) 'Green Lantern' custom brewing here.
Steal their bike (much nicer than the white one)
Replace engine
Link Removed
Wallet - you'll need a big one.
Link Removed
Mask - to get into character for every ride
Ring
Helmet cover
T-shirt
Chinese LED headlight with green halo
Four blinkers using these
Tank spray job
I'll take a hit off that.......
There are high performance diesels, that wedged into a relatively lightweight Rocket would give impressive performance. Diesels themselves though are often heavy to withstand their compression ratios, so there is a potential road block. It's a design thought, and engineering exercise and it doesn't need to have a point. Just thinking of it and bandying ideas around, we might come up with something. And you would be the first customer!
Nah the diesel scooter thing is not my bag. But, the V6 Twin turbo 2 speed scooter thing and I'm prolly a player.
Just sayin, ya never see a diesel scooter in the NHRA finals.
@BigNorm - way back in the 70s, I had a friend in Southern Africa, converted his Mach 1 Ford Mustang to run on Kerosene.
Used to see him at the gas station, filling up with the women from the local low-cost housing areas gathered around restocking their containers of kerosene for hurricane lamps.
I put 25% kerosene in my Landrover Series III quite often during gasoline shortages, long as you don't overdo it - acts as an upper cylinder lubricant .
Diesel - I'd imagine a Cafe racer for the Rocket III, something like this
@Performance & Diesel Centre on FB have a couple pictures of Rockets on their page (though not diesel powered of course)
A turbocharged version of the Mercedes Benz 16 valve diesel engine became their new 190E engine Displacement: 140.3 cid (2,300 cc) specs on that engine are here Specifications
There's a good article here 12 High Torque Motorcycles | RideApart from Sean McDonald
Another good write up here on Wikipedia that explains why we see fewer diesel motorcycles Diesel motorcycle - Wikipedia, the free encyclopedia
You've probably seen this on the web recently too - Look at the Military’s New Stealth Bikes
- so you are definitely not alone in your thinking.
Wikipedia sums it up @BigNorm - "...with a traditionally poor power-to-weight ratio, most diesel engines are generally unsuited for use on motorcycles which normally require low weight, compact size, high RPMs and rapid acceleration". Your Rocket would not be what she is today and would certainly not make it to the Salt Flats with Castrol :-(
So once again it looks like Rods may be the weak link. Rods can be made stronger. I wonder what the journal sizes and rod lengths are on the Volkswagen TDI motors? Mercedes? Ect.
YEP thats all we need a big stinky smelly slower motorcycle
