vocaldog
VocalDog
I finally got the Tune ECU to hook up! It says I am running map 20055 and that my speed sensor circuit is malfunctioning. Could that be why it intermittently runs VERY rough at both idle and at speed? Now, I just have to be running for that info to come up? Ignition is on and kill switch is in 'run' position. Now, I just have to figure out how to save and load maps Thanks again!
I noticed a lot of moisture trapped in my speedometer and I wonder if that could be the source of the speed sensor malfunction? I'm going to disconnect it and clear the code and see what happens. Could that be the source of the engine running really rough at idle and at speed? I thought it was probably a TPS problem. So got HansO's MAP loaded to Tune ECU, but I still can't seem to get any voltage reading from the TPS at all. Stumped.
