Guidance needed: Derestricting 2020 Rocket 3 GT using TuneECU & OBDLink MX+
Removing the fuse does not stop the headlights on my 2020 R. Its apparently a quirk of the 2020 model wiring. Only way is to remove the light cluster and disconnect the harness manually. My battery charger could not keep up with the battery drain with the lights on, so to be safe im going to disconnect the lights before I try the Penner flash.
Are you sure? I have the 2020 R and, it's been a while, but seem to remember pulling the headlight fuse
I have a 2020R and pulling the lighting fuse does not turn off the headlights! It’s a wiring quirk peculiar to some 2020 bikes.
I left the lights on and connected a high output battery charger and had no problems loading the Pemmer map. On advice I didn’t select the “Reset Adaptations”, or do the 15minute idle thing. Instead I just rode the bike which apparently relearns as it goes.
