DEcosse
If it's no Scottish it's CRAP!
Std/Classic have 25L tank (6.6 US gals)
Roadster has 23.5L tank (6.21 US gals)
Touring has 22.3L tank (5.89 US gals)
To convert to US gals - Liters to US Gallons (Liquid) conversion
(note that you will need to change the format field to decimal and accuracy setting to three significant figures)
Note that the User manual recommends filling to the bottom of the filler neck - you can also use this as your reference level for before and after fill point points - as long as you use the same reference for both, when you do your calculation.
(I would imagine that is why the manual stated volume is a bit less than the 'actual' volume when filled to the top of the neck)
Does anyone do this? I always fill it to the absolute
