atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 4,086
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
If you had that spring reversed, you can't get any fluid down the lines. If you look at the holes at the bottom of the reservoir and actuate the brake lever you should see spring coils moving by the hole. The piston with the o-rings is the pressure boundary and the rubber cup on the spring is the fluid seal, so all that stuff is opposite the banjo fitting. Spring large end goes toward the banjo.
