Fluid leak after Ramair Installation
Marcr
Rocket 3 Roadster
Hi Everyone,
I recently installed the Ramair onto my Rocket 3 Roadster (2016), I have now got a fluid leak on the left hand side, that when wiped up has a slight green tinge to it, is it possible that this is some oil from the Ramair filter just trickling down as the engine gets hot? It seems to be less after the third ride. I initially thought it was a oil ring leak under the oil tank, but the fluid seems to be a different color.
Before I take it to my dealer, has anyone had a similar experience or agrees with my diagnosis/guess?
I didn’t notice any fluid prior to my installation of the Ramair filter.
I have not seen anything like this after my RAMAIR install a little over a week ago. I would not think it is anti-freeze from the area In question.
Thanks Guys,
I’ll open up again and check the pipes, I didn’t relocate the coolant bottle, but it’s possible I disturbed a pipe during installation.
Just throwing this out there. There are a couple of bolts that hold the thermostat housing on and also a bolt just above the thermostat housing that is a coolant bleed. If for some reason you loosened a bolt in that area it could lead to a leak. ?
any pics of the ram air system , where did you get it from ??
How many do you want ?;):cool:
TR-111 from UK
Cost Aussie$215 (US$148) delivered to an Aussie or NZ address
Part Number: TR-111​
What vehicles does this fit?​
This kit is compatible with the vehicles listed in the compatibility section above. If your unsure at all about choosing the correct part for your vehicle, just contact us via eBay message.
This is the highly acclaimed Ramair Triumph Rocket III air filter kit, sold the World over, this kit is a great upgrade to the Triumph Rocket III. Its gives a dramatic improvement in air flow from the OEM filter and Intake System which in turn leads to better throttle response, torque and more importantly horse power.
The kit is compatible with all current standard Rocket 3 variants, including the Classic, Roadster, Tourer and Touring
The kit comes with all the parts needed to install and has an 8 page fitting guide with photos. There is also wide community support for product including many installation videos on Youtube made by Rocket 3 owners themselves.
  • User serviceable, washable, lifetime filter element
  • Full radius inlet necks
  • EPDM base for durability & strength
  • Wiring extension harness for Intake Air Temperature sensor
  • All ancillary clips and clamps required for installation
  • Full foam crankcase breather filter
The install fits under the standard bear claw cover, meaning no modifications to bodywork or chassis are required.
This is a unique out of the box solution for all those wishing to tune and upgrade the filter setup on their Rocket III. Utilising our specialist twin layer filter material which is pre-impregnated with our own bespoke dirt retention dry polymer the air filter element itself is born from our extensive Motorsport and OEM experience.
Our filter come with a lifetime single user guarantee against manufacturing defects and are made from FMVSS302 flame retardant twin layer foam. It is recommended that all new filter installations have a full AFR check as a remap is likely to be needed.
WHO IS RAMAIR FILTERS?​
We are a UK registered company with technical and sales staff on hand 5 days a week.
We design, test, manufacture and assemble right here in the UK.
We are trusted by no less than 4 major car manufacturers to produce performance filters for their road and race car applications.
We are not just resellers of product, you are dealing direct with a trusted manufacturer, no middle men involved.
