That's why I'm glad I don't have it
, 08 R3T changing fluid easy pezzy. No ABS, I would want to bypass that.
But the problems with older bikes, had mine out over the weekend and twice it just shut down while driving, let the clutch out one and the back wheel locked up, thought I seized the motor for a second, stopped and it started right up, so I've been looking around on hear, I see people saying it maybe the TPS, or stepper motor, but I also read the ignition switch or the side stand switch, I'm getting like 26 mpg so I think I'm going to go back to the old tune and adjust the TPS, and stepper and spray some contact cleaner in the ignition switch and check the connection block, and if all that fails I'll replace the stand switch, I happen to have a used one from pinwall, I also have a used TPS I can try, might have a used stepper too. It's starting a little slower, have to take a couple to a few starting sequences, pushing the button, before it starts, last year started right up, so I'll keep you guys informed if I find it, I don't think it's the neutral switch or clutch switch cause that wouldn't shut it down all of a sudden unless the stand is down. I think the last time I set the TPS it was a little jumpy, so after I change the tune back if that doesn't work I'll change the TPS.
I think I have the penner tune, I don't think the adaptation completed, not sure, but it should adapt after 15 minutes of riding and it ran fine after the change a few thousand miles ago. I don't know but I know it's really rich, may get a really Dyno tuned at the shop. Whatever tune it is, it increased the power meter on a my bottom
very noticeable
I think I'll want to request the secondaries stay open, I think that was the biggest difference, all I have is TOR's, K&N air box stock replacement, and de-cat.
I got it last year with the TOR's and did the other 2 and a Tune ECU, Myself.
Keep your fingers crossed I don't have to push it or have it towed too far, ran fine all the way home like 40 mile.
Hope you all have a good day, keep it between the lines and stay away from big hard objects, like cars
