MIG
Road Therapy...
- Joined
- May 26, 2014
- Messages
- 3,050
- Location
- Tucson, AZ
- Ride
- "Fiona" my '14 R3T & "Delilah" my '16 V-Rod Muscle
I'm just shy of 30K miles on Fiona and I decided to go ahead have the valve's checked. Each one was out of spec. With the intake valve spec being .10-.15 mm, mine were .18 .23 .18 .20 .20 .20 respectively. For the exhaust valves, the spec is .15-.20 mm and mine were .25 .25 .25 .25 .25 .25. I almost think the exhaust valves came that way from the factory. Glad I had it done and our local Triumph dealer here in Tucson did not take me the cleaners. Since they were doing the work, I also had them lube/adjust the head bearing, change the final fluid, install new spark plugs, adjust the throttle bodies, replace the brake fluids, drop in a new air filter and lube everything else that needs lube. A lot of that I do myself, but it's to **** HOT!!! and I needed it done. My dealer was AWESOME! and they'll be seeing my again. I just wish they wouldn't use the engine cut-off switch (like the owner's manual states). First thing I did when I got home was do a 12-minute tune.
Since there's always talk about the valve spec and need for it (or not). I thought I'd share my results here...
Interesting note on the engine cut-off switch, I was talking to a HD dealer (with my V-Rod) and they stated they don't use it either as it's a common failure point. They obviously don't build them as good as turn signal switches (which get heavy heavy use...).
-MIG
-MIG
