TURBO200R4
stand up straight and grab the world by the a$$
I believe I've found my divergent weave root cause. Still doing new bearings today for good measure. Zero play in headstock, but I'll have a set on hand + tools if it persists.
Funnily enough, I had the steering damper cranked to max when I lifted the front end, the revised mounting point nearly doubled the force exterted on steering, so that's a big win.
The actual balance point is with the visible wheel weights at 4:30 clock position.
Again, a dealer demonstrates they're trash and not to be trusted.
Will be buying one of these to avoid putting my faith in "mechanics" in the future:
TiRx Motorcycle Tire Changer
What It Is: The TiRx Changer The TiRx tire changer is a newly invented and designed tool. It is made of steel box tubing, plate and round bar stock with plastic rollers and an organically shaped tire bead guide. The tire changer weighs less than 20 pounds and has three moving parts. The main...www.tirxmoto.com
i would say it is a great idea to double check the work
even if it is your own work
lol
