sleeves
Nitrous
Hi Sleeves,
Would you have a ECU tune that would help with a 2004 and the DP shorties? anything better than the Tor tune. might also look at a Ramair intake if that helps?
Cheers
PM me with your VIN no and I'll have a look. No promises as the DP "exhaust" is really just a dump pipe, to stop backfire on the throttle off its a matter of either enriching up the mixture till it cannot backfire, or cutting off the fuel, enrichment is safer, but it has to be done at the correct point. That's why the TORS "tunes" wont work well.
I have a MAP from a D&D system I had on that used to backfire like a B before I loaded it. Not sure if it will load to your ECU though as mines an 05 The pipe was longer too and I had it baffled more than the OEM D&D pipe to shut it up so gas flow was not as good.
Watch this video. Young guy, describes things clearly.
Can only try take it your OK with loading maps?
