Clutch Failure
Try power of prayer!
Can I butt in here...I'm new to the R3,I have an 06 rocket..it seems the clutch is really noisy on mine,when I pull the clutch in its quiet but let it out with the motor running and it sounds horrible.
They are a wet clutch?...are they normally noisy?..my first r3 so I have no idea.
The dealer just fixed the output bearing on the driveline which was also buggered..im running out of time if I want to take it back again.
Actually even riding it its almost got a clutch rumble.
Any help/advice would be appreciated.
@nzfreeriders I have to guess, 2006 with a silver motor?
06 with a black motor..after reading the posts im wondering if the bearing behind my pressure plate is on its way out...I just dont know how noisy they are normally.
They do rattle a little the older style clutch rattles more IMO. It does show a improvement with the newer lifter piece in it as the head is larger so there is less room to rattle around in the lifter shaft pocket. I would say you ok unless it is real bad then I would open her up for a look see.
Thanks..had me worried for a while there...now I can get back to enjoying the new beast.
