DodahMan
Turbocharged
- Joined
- Jun 12, 2017
- Messages
- 509
- Location
- Coastal South Carolina
- Ride
- Yamaha Roadstar, 2011 Triumph Rocket III Tour
The dimples MUST align - PERIOD. Attach the arm correctly and if you get ANY progressive increase in tension rotating the assembly around to where the cable end is - the spring is attached. The arm is PRE TENSIONED in its' "disengaged" position. If you have no pre-tension - get ready to open her up.
ime - if doing this alone - it is easier to attach the lower end of the cable to the arm first then slot the cable outer into the lower support then route teh top end upto the bars.
Thanks, there indeed IS spring tension when I turn the shaft counter clockwise. It is just that there is not much tension. What you said here about the arm being pretensioned gives me confidence I might still be ok.
So, when rotating the arm left to the stop where ALL spring tension is loaded on the cable, setting the cable and tightening ONLY THEN will the clutch actuator plates lift when the clutch lever is pulled. Is this thinking correct?
